1 - 13 of 13 Posts
Hey guys, my suspension is really squeaky and I was hoping to get some idea what to try. I tried greasing the front end and spraying silicone spray on the shock bushings but neither has helped. Any other ideas? Here’s a video... thanks
Squeaky x3 video
Your brakes are gonna squeak like a mother trucker to! Once your out on a dusty ride for awhile the whole car is gonna get squeaky!
Pull the shocks and lube the bushings as described in the manual. It will go away for a few washes.
Reactions: New XRS Guy
Mine doesn't squeak at all haven't heard a squeak in over 7 mos, but , haven't had the car out since last nov. when we did the peace trail, been doing up grades since the commi’s closed our deserts to riding because you know out in the desert you might get farther than 6’ away from somebody and thats not acceptable , you need to be standing on the x at home depot to be safe
My car was squeaking real bad in the rear took me a while to figure out what it was. I ended up putting new FK heims in my ZRP radius rods it changed everything....way quieter ride now.
Discussion Starter #11
Thanks guys, I’ll try a few more things and if nothing works I’ll just deal with it
My 2020 XMR Started to squeak after a few uses/washes as well. Got some BRP suspension grease, loosened front a-arm bolts and made sure it got pushed out at more than 1 spot, tightened down and front is whisper quiet now
1 - 13 of 13 Posts
