General consensus seems to be the stock shock springs are a little on the el cheapo side.....Is there any advantage to replacing them with a good set of Eibachs, or something? Or do you not net enough to make it worth it?
Thanks Alex.....really all I was going for was just a better quality spring that will hold up better and maybe ride a little better. Ultimately, my shocks will go to you for a re-valve, but if there's any value in a better spring, them Im for that too.Depends on what you're looking for. If you have issues with the springs or suspension I can get you new springs. The stock springs literally where purchased for less than $10 a spring so the quality isn't too good.
Softer, Im ok with....Saggy, Im not. Are you getting sag too?my rear shocks seem to be getting softer as well is it the springs u think
Interesting idea. Anybody else try this?If you really want to improve the ride for as cheep as possible swap your front springs and rear springs, IE put front springs in the rear and rear spring in the front, don't swap the shock bodies just the springs. I always noticed that the front end would dip under hard braking and turning and fought with the widely know back end bucking. So when i was replacing the worn out factory orings on the spherical bearings I swapped the spring just to test it out, its free right, and i really like the new ride. I am sure people will argue with me and that's great the more people being open about what they have done and how its works the better. If you are like me and spent your small fortune on the maverick and don't have money left over, the spring swap is your best bet. I have a 2014 xrs and the podium 2.5 so i am not if the swap will work on 2.0. It is important to note that I have a winch, bumper and lights hanging off the front making the front end a bit heavy. Also from what i can tell the stock rear springs are around 207lb and the fronts are around 175lb, switching them out made a huge difference for me, you will notice your rebound and dampening adjusters actually start working.
The rears are longerInteresting idea. Anybody else try this?
