1 - 20 of 79 Posts
It lets you have sport mode in low range. From the factory you can't put it in sport mode while in low range so you only have about 70% of your power. I just put the one made by articbomb on mine but havent been able to try it out yet, still putting the snorkels on.
Reactions: BAMA-S
Reactions: n.s mav
Yea that is the switchless version. He also sells a switched version for $190. Both perform the same function. Just depends on if you want a manual switch or not.
Thanks…got it……kinda spendy isn't it?
I hear ya…but for some wires and good quality connectors…this is a bit extreme……If I had the wiring diagram for the harness, i could build it myself for around $20 using the same quality connectors. I could do it for around $3 if I cut into the stock harness…..
Will the current sport low mod out work with the max? I am looking at the switch less plug and play version.
It should work but you may have extend the wires if the engine is not in the exact same location.
Yea, I think the the kits from articbomb are a bit rape cost. He also sells a fan override kit for $105 but UTV inc sells it for about half price.
Yea, I saw that….granted he uses great quality connectors but they don't cost that much and other than that, it is wires and cable loom…..
Mike who I ride with is an Engineer at 3M, he's going to do one and sell it for about $40 or so, maybe less. He agrees it's rape. Hopefully he follows through and helps us all out. =)
1 - 20 of 79 Posts
