Spare Tire Mount $175 Shipped
- This can be used with a stock machine, no special bumpers or roll cages needed.
- Allows you to still store/attach other items to the bed/cargo area.
- Attaches to vehicle frame with bolts. (no drilling required, uses factory holes)
- Holds up to 11 inch wide tires. Might be able to handle 12 inch wide tires but call me before ordering if you plan to mount a 12 inch wide tire as your spare. I will make sure it doesn't hit the rear plastics.
- Comes with 4 studs and lug nuts. (4 x 137mm stud pattern)
- Comes with durable textured black finish
- Product only weighs 8 lbs and a tire is fairly light so it will not add much weight considering the machine is 1300 lbs dry or 1650 with 2 passengers. The 30 pound tire/rim will not make a difference in handling or performance.
Call with any questions 651-968-9681 ships from 55304
