41 - 51 of 51 Posts
I wanna ride Mike
If you don't carry a jack, carry a tow strap. Throw it over the roof and tie it to the roll cage. Hook the other end to your buddies car and he can lift both wheels on 1 side off the ground for an easy tire change. Technique is almost faster than using a jack.
Just as long as @Sandshark is not the dick on the end of the rope who pulls too much and rolls your newly built car over for you. Lol
Plugs, Sidewall Slugs, etc can fix lots of problems. When this happens you need a spare.
265972
1600 miles onX Rc turbo r, 2 flat tires. Second one was sidewall damage. I slid into a big bolder in a wash in a turn. Bothe times I put the spare on(stock size) just back the good side tire up onto a big rock or ledge at an angle and the bad tire comes of the ground, might need to move a little dirt But no jack needed. I carry a jack now, but if there is a big rock or something I’ll do it without fumbling with trying to jack it up. I have a spare carrier that puts it above the back window, I can still see out the rear view mirror. I did roll over last week, I guess it could have contributed to it, but that’s life.
Sometimes I carry a spare, sometimes not. If im leaving only for a day and I know I wont be more than 200-250km ( 125-155 miles for my american friends) away from my trailer, I dont carry It. If im leaving for a 2 or more days trip I strap my spare to the bed because it would suck to cancel a trip because i cant fix my flat tire. I ride east coast. Forest trail, fire road, log truck road, gravel, hardpack and roots and rocks. No sand or desert.
I do carry all the time a bunch of plugs, a jack with a compressor and also an equalizing tube
(silicone tube of 10 feet with a screwing air chuck each end so you can transfer air between tires if your compressor dies)
Reason why I avoid bringing a spare if i dont really need to : it takes a lot of space ( i run 32x10x15) so bed boxes and cooler is more complicated to fit and I HATE straps. And it weights a lot, i think 55 pounds my combo rim/tire and i noticed on big bump/hole or rocky section when riding fast, my rear skidplate touches ground sometimes. I have a 64'' with 15 " ground clearance.
Did i ever suffer punctures and flat tires: oh yes. Always sidewall punctured or sliced, never ever had a flat on the contact patch. I was always able to patch and air up! I have never used my spare because of a punctured tire.
Only time I used my spare Is when I had OEM rims and i hit a rock and the rim bent or cracked and it wasnt holding air anymore. A patch cant fix this so spare was needed. It happened 3 times In 2 years before I decided to buy aftermarket rims. It never happened again with my method rims and 32 inches tires combo and i've been running this for 2 years.
And to be honest, i would have no problem riding on a flat tire or even the rim itself for as much km as i need to come back to my trailer if i wouldnt have a spare and wasnt able to fix the flat. There is no way I would walk for hours just to save my rim!!!! But thats me.
In the end, it your decision. Is a spare mandatory? Absolutely NO. Is it usefull? sometimes yes but most of the time no.
Plugs, Sidewall Slugs, etc can fix lots of problems. When this happens you need a spare. View attachment 265972
I carry epoxy stick, you would be surprised of what it can fix!
I once lowsided my motorcycle during a trackday and explode the clutch cover. We used 2 stick of it to shape a cover with was was remaining, waited 1 hour for it to cure and harden, filled the bike with oil and I was able to finish my trackday haha. I mean, if you have a spare dont bother, but epoxy stick would temporarily fix something like this.
Fixing a clutch cover to hold oil and a wheel to hold air pressure are quite different. Not saying it would not work because I have no experience using it. I would rather have the spare and not have to worry if it will work or if it will hold or not after the repair. It is all a matter of risk and how much each of us are willing to accept. For me the spare is worth carrying to mitigate the risk. I have two X3s (me and the wife) with the same wheel/tire combo so the spares are compatible. If we have an issue (need a spare) we can continue normally knowing we have a second spare between the two cars. Again, to each his own.
@blackdiamond you are right. Cover to hold oil vs rim to hold air is different. ...but epoxy stick is still an awesome thing to carry.
To me carrying a spare for short ride is more of a hassle than having no spare. To each his own is totally true.
41 - 51 of 51 Posts
