1 - 20 of 25 Posts
Within three months I've had two primary clutches replaced. I picked it up today after having the second clutch and a new Gates belt installed. I took it down the trail for a test run and it seemed like the transmission would slip around 30mph. A transmission signal fault message displayed across the dash and the engine shut off. I started it back up and it sounded like the engine was knocking and wouldn't idle higher than 500rpm. Lucky for me, I was in my yard trying to load it back on the trailer at this point. I dropped it off at the dealer and the service manager mentioned mine spends more time there than my house and it's the only unit they've had come back with problems. Sorry for my rant but I'm pissed and either looking to lemon law it or try to sell it back to the dealer. Have any of you contacted Can Am directly about your Maverick?
Call can am directly and let them know your problems, anything can be fixed and it sounds like a clutch related problem which is the biggest fault to the maverick. I know its hard to spend the cash but I'd bet a aftermarket primary would fix your problem and get a nice performance boost
Primary wont have anything to do with a tranny problem. But your right an aftermarket primary fixes the biggest problem with the Mav.
Hickory, NC
Sorry about your troubles, most all of us are free from trouble and I might consider that you change dealerships for service or buy a manual and tackle the work yourself. A new primary would be added insurance for you. Question, do you drive it in high gear even at low speed? This will fuk everything up! You can't trail ride in high gear, under 35 mph, buy a sport low switch and watch it come to life in low
Hickory, NC
I assumed you were trail riding? The belt temps will become too great in high at LOW speed. If you're doing more than 35 in high it's fine
no one has reported a problem like yours and a light come on for tranny to , so im sure they will get your lemon sweeten up !
Discussion Starter · #9 ·
Got it! We'll see what they find out Tuesday. At this point I feel like I've blown 18 grand. I'm going to try and get a new maverick or at least an extended factory warranty. I'll call Can Am tomorrow. Thanks guys!
Good luck, I keep mine in low up to 30 and it does fine. I haven't bought the sport low switch yet. Haven't needed it where I ride.
I ride in high on all machines I ever owned.. You just have to know when to use low, like slow ridin on ruff trails with rocks, logs and hills and such....maybe I just know how to drive better then you guys..:) lmao
Bama, If you already use low all the time and don't have sport low because you don't think you need it, you are missing out. It's like a new machine when it come to trail riding and hill climbing.
X2 this is how its done!!!! Low is only for high load situations or bigger tires or mud bogging 20 mph max after that your just screaming your motor for nothing. Gncc racers never use low
1 - 20 of 25 Posts
