101 - 118 of 118 Posts
IMO, you still need lower a arms, and rear radius rods. "Then" you should be pretty well set.
I’ve done it to my last two cars. Both different brands. It’s Good security. I’m going to use the stock for a while and call it phase 2. Haven’t seen a 10 bolt rear plate yet and assume someone reputable will expand their insert kits.
Anticipation........
Now I’m going to have that song in my head all day.
It does give me time to return my winch bumper for one compatible with the CT bulkhead kit. Also finding limited options for the Warn Axon 4,500lb winch I bought. Rage Fab is taking care of me which is really cool, but I was surprised with the limited options for a close fitting bumper that doesn’t add length or take away from approach angle to fit the CT kit and an Axon.
Yeah, since you have time, plan it all out, get what you need. Case in point, the rivnuts / rivnut inserted, and correct drill bit (I believe it's 13/64, but check threads) for when you remove the rivets on the rear skid plate. Get a grease tool for the wheel bearings. Extra oil filters from Rocky Mountain ATV. You get the point, LOL.
I have a shock tower question from a different (possibly stupid) perspective. Since there is already the piece that I thought was a brace from the upper shock mount, is there a brace that uses that stock upper piece and ties into the frame? I always like modifications that don't look like modifications.
Not that I'm aware of.
2020 XDS RR, 2019 Sport 1000R
Braces improve the look imo.
