161 - 174 of 174 Posts
And this is why I won't use them again. Seems like such a simple solution to fix it. Doesn't happen with Eibach springs. Yet they keep selling spring kits like this, telling people this is normal and that crossover rings are a "wear item".
Yep, I'm sure not impressed and wont be going with ST in the future on the Other X3's.
Your springs are also wearing, you can see a flat spot in the your last photo. I'm sure I have tried every number on the clock and still had the same problem. New sliders will help for a couple hundred miles.
I figure when they wear enough to be a real issue, I'll get new parts and Eibach's.
2020 XRC Turbo RR
His sliders look almost worn through. I'm not convinced the ST spring are the only factor causing the wear in the pictures.
I'm pretty confident it is. I had a RZR Turbo that I ran Eibach springs on for probably 2000 miles or so, crossover rings and sliders looked as good as new. No problem whatsoever. Decided I wanted to do a revalve and chose to take it to ST. Bought their springs and they installed everything. In less than 1000 miles my stuff looked very similar to his. ST said this is normal and crossover rings are a wear item. They were happy to sell me new ones though. A quick Google search will show you this is extremely common with their spring kits and they give everyone the same response.
mud and debris between all of the moving components combined with less spring clearance.
I'm sure mud and debris aren't a help, but this was within 500 miles and it was winter/early spring and cold so it's not like I was out mud running it. Even if that was the sole cause, it's still a design flaw from ST and they take zero responsibility.
In my opinion, ST cheapened up the spring by making it the same diameter the entire length. They made springs that don't seem to want to sit flat and because of that I'm ruining other shock components. I drank the Kool aid and now I have regrets. SO GLAD I didn't buy their steering rack based on others experience.
2020 XRC Turbo RR
So....the spring is really the culprit.
It sounds like it certainly could be but it is hard to tell with how filthy all of his parts are. I'm not experiencing the same problems but I have different shocks. I asked previously if this was primarily an issue with the 2.5" shock but no one seams to know. I'm not seeing the same complaints from 3.0" shocks which appear to have more clearance.
2020 XRC Turbo RR
I don't think I'd buy ST's springs again given what I know now. Eibach didn't have springs available at the time though. ST has a track record of blaming everyone else which really sucks. I still think you need to clean your car, there is corrosion and mud on the shock bodies in your pictures.
Its super clean right now!… and it will be for at least the next few weeks till I get it back. I do spray it off after every ride, but I use it around the farm in between so unless I wash it daily (which won’t happen) it’s always going to be some level of dirty.
Edit: FYI On my spring build sheet. I did put in the additional information to consider that I wanted to account for an extra 100lbs of mud that was likely to have on it all the time because I ride in the East and that’s all we have.
Sublimeshooter
Rear Upper:052321
Rear lower: 002361
Front Upper: 00338
Front Lower: 002361
EDIT: 2 seat 64" "set up for trail"
Earlt.peeples
64in XRC
Rear Upper: 052321
Rear lower: 002361
Front Upper: 00338
Front Lower: 002361
X3 Poor
2019 XRS (172HP/72")
Two seat, very light car, very light passengers, Dunes 90%, have IQS installed.
Front Lower = 003361
Front Upper = 05238
Rear Upper and Lower are same = 00257361
Triple Black
Front upper: 00438
Front lower: 004361
Rear upper: could not see
Rear lower: 05257361
tn776421
2021 X3 DS Turbo, 2 seater.
Front 005338
002361
Rear 002321
002361
Cascade Crush
XRC RR
Front:
Upper: 05238
Lower: 003361
Rear
Upper: 00257361
Lower: 05257361
Superlate
Max XRS … 2 people. Some accessories.
Front
Upper 05338
Lower 053361
Rear
Upper 00257361
Lower 05257361
Supersmith
2021 X3 Max (Very Heavy) Spring set up done at Shock Therapy
Front
Upper 00438
Lower No Numbers on either lower springs.
Rear
Upper 00357361
Lower 05257361
Wicked can
21 xrc 72 wide. Tool box and small cooler on back. Extra 10 gal fuel tank under seats. Set up for driver and passenger.
rear upper and lowers. 00257361
Front uppers. 05238
Front lowers. 003361
Speed Buggy
22 XRS Smart Shox
front
Upper 00338
Lower 003361
rear
Upper and lower the same 00257361
DogRunner2
19 XRC 64"
Frt. upper 00338
Frt. lower 052361
Rear upper 002321
Rear lower 002361
I'll keep it running.....
