141 - 160 of 174 Posts
2020 XDS RR, 2019 Sport 1000R
The worn crossover rings.
That's after only a couple days of riding. To be honest I haven't tried to clock them into a better position yet. Hopefully that helps but I think it's 50/50 it will work.
I can remember Justine mentioning the the acceptable QC tolerances ST will accept for how "straight" their springs are is very strict, and the top and the bottom of the spring has to be within a couple % points or something like that. But you can see some of mine are bowed a bit by eye. Car rides pretty good but I'm not having perfect luck with Justine's products.
Wood Automotive tire Gas Tints and shades Automotive wheel system
Wood Gas Tints and shades Art Metal
I need to check my Eibachs but I do not remember seeing any wear.
I'll take a closer look later. I've had the springs on for about 5k miles.
2022 X3 XRS RR SS
Sublimeshooter
Rear Upper:052321
Rear lower: 002361
Front Upper: 00338
Front Lower: 002361
EDIT: 2 seat 64" "set up for trail"
Earlt.peeples
64in XRC
Rear Upper: 052321
Rear lower: 002361
Front Upper: 00338
Front Lower: 002361
X3 Poor
2019 XRS (172HP/72")
Two seat, very light car, very light passengers, Dunes 90%, have IQS installed.
Front Lower = 003361
Front Upper = 05238
Rear Upper and Lower are same = 00257361
Triple Black
Front upper: 00438
Front lower: 004361
Rear upper: could not see
Rear lower: 05257361
tn776421
2021 X3 DS Turbo, 2 seater.
Front 005338
002361
Rear 002321
002361
Cascade Crush
XRC RR
Front:
Upper: 05238
Lower: 003361
Rear
Upper: 00257361
Lower: 05257361
Superlate
Max XRS … 2 people. Some accessories.
Front
Upper 05338
Lower 053361
Rear
Upper 00257361
Lower 05257361
Supersmith
2021 X3 Max (Very Heavy) Spring set up done at Shock Therapy
Front
Upper 00438
Lower No Numbers on either lower springs.
Rear
Upper 00357361
Lower 05257361
Wicked can
21 xrc 72 wide. Tool box and small cooler on back. Extra 10 gal fuel tank under seats. Set up for driver and passenger.
rear upper and lowers. 00257361
Front uppers. 05238
Front lowers. 003361
I'll keep it running.....
Mine showed up this week, waiting for some sand craft limit straps to do the swap
front
Upper 00338
Lower 003361
rear
Upper and lower the same 00257361
they came with some scratches. This is my 3rd car with ST springs and the first time they are scratched and have paint rubbed off where it looks like they were hanging on a rack or something
Automotive tire Coil spring Wood Audio equipment Gas
Cutlery Hood Tableware Audio equipment Wood
front
Upper 00338
Lower 003361
rear
View attachment 280950 View attachment 280951
What model ride is yours again?
I remember it's new so I'm sure a 22
Sublimeshooter
Rear Upper:052321
Rear lower: 002361
Front Upper: 00338
Front Lower: 002361
Earlt.peeples
64in XRC
Rear Upper: 052321
Rear lower: 002361
Front Upper: 00338
Front Lower: 002361
X3 Poor
Front Upper = 05238
Triple Black
Front upper: 00438
Front lower: 004361
tn776421
Front 005338
002361
Rear 002321
002361
Cascade Crush
XRC RR
Front:
Upper: 05238
Lower: 003361
Rear
Upper: 00257361
Lower: 05257361
Superlate
Front
Upper 05338
Lower 053361
Rear
Upper 00257361
Lower 05257361
Supersmith
Front
Upper 00438
Rear
Upper 00357361
Lower 05257361
Wicked can
Front uppers. 05238
Speed Buggy
22 XRS Smart Shox
front
Upper 00338
Lower 003361
rear
2020 XRC Turbo RR
If we use ST's naming convention, the 3" RC2's get 3.75" ID springs while the 2.5" RC's get 3" ID springs. This suggests there is less clearance for the smaller shocks. I haven't driven in muddy conditions so possibly foreign debris could get stuck between the spring and divider but I can't force the spring over by hand enough to contact the rings.
21 X3 XRC
Discussion Starter · #155 ·
Could be part of the issue is there tollerence for spring straitness and then add in the fact they are using 16” long on the uppers as well as lowers. Eibachs are not using 16” upper and lowers so less room for flex in the spring as they extend maybe. Just a guess on my part.
