1 - 5 of 5 Posts
What am i doing wrong? I pulled the clutch itself off because I was changing starter. I now have clutches on and went to install the belt with the changing tool and won’t compress? Tried tapping with a rubber hammer still nothing
258789
did you rotate the clutch?
it must rotate to close with a belt in it
if you did and it still wont close, then you have
broken parts....
probably a broken roller jammed up
or a broken spring
1 - 5 of 5 Posts
