1 - 7 of 7 Posts
2019 Maverick XRC
So I got the float mod done, put my clutches back on today and then realized there’s additional hardware and a new procedure for installing the secondary. Now it’s stuck on the shaft. Any ideas how to remove it? I tried a slide hammer with straps, no go
I assume it must be some sort of press fit issue
your sure you removed the bolt...lol
you must have twisted/stripped the splines
2019 Maverick XRC
Discussion Starter #5
No it slid on easy. I started it and let it idle for a min and then tried to remove it. It has something to do with whatever they do for the kwi float mod
Take the belt remover tool put a eye bolt thru the center hole hook your slide hammer to that and now you are pulling in center , getting rid of the strap allows you apply much more pulling force. The strap is a shock absorber
1 - 7 of 7 Posts
