21 - 25 of 25 Posts
But be VERY carefull knocking them back in go just far enough to get the bolt in, it is very easy to go to far and go through the very thin end stop, Ask me how I know!
use a long 4mm bolt, or the same as you removed them with
if you use a punch you can damage the threads and make it a real nightmare when/if you change the rollers again
Correct and good point. I used a brass punch larger than the inside diameter of the pin, that wouldn't damage the threads. Definitely don't use a steel punch.
Discussion Starter #25
Good info. Thanks everybody! Out of town on work so will be another week or so before I can finish the job.
21 - 25 of 25 Posts
