1 - 4 of 4 Posts
Here is the deal.
I have a 2015 xds turbo with the following mods
Stage 5 evo tune
cat delete pipe
slip on muzzy
evo charge tubes with tial blow off valve
bigger injectors from evo.
boost gauge showing 12lbs currently running premium gas
What boost level can I run up too without buying a bigger turbo.
I am looking at getting the map x from evo.
THanks
C
I am not entirely sure, but when I was researching my compound turbo setup on my Dodge I read an article that explained compressors are designed with specific limits in mind, and if you put enough fuel through an engine, it's going to run up against a point where the turbocharger becomes inefficient.
According to places like Alba racing, and evolution 12lbs is the safest and only with injector and turbo upgrade can you make more power!
16 psi is the limit with the OEM turbo. After that it's just blowing hot air and runs out of efficiency. I had albas 16psi race tube and it was a monster. You had to be on the gas in order for it to "come on". It was kinda flat of the bottom end. I liked it though
1 - 4 of 4 Posts
