1 - 6 of 6 Posts
I’m installing the stage 5 on my 2020 maverick x3 but I came across a problem when I tried installing the subs with the enclosure, the video I was following doesn’t show what to do with the break lines that are in the way, there isn’t enough slack to go under them or put the enclosures over them, and it is the X317 so everything should be compatible
Well ended up figuring it out and it’s all wired up and sounding good.
How did you end up mounting the plastic control module above the steering shaft? Their was nowhere to screw on to the replacement Rockford fosgate dash cover
Discussion Starter #4
There is to little indentation marks where you drill two hole with a 1/8 drill bit and they provide two screws to secure it in place
2019 x3 Xds R
I 4 point zip tied mine to the harness on top of the steering column. Seemed way more stable than the plastics.
1 - 6 of 6 Posts
