1 - 7 of 7 Posts
I'm trying to hook up a dual led rocker switch for my led light's. It's a Carling switch from air on board, got it hooked up and working, only problem is the top led is lit all the time and the bottom led comes on when switch is activated. Should be in reverse, I Followed the included instructions.. Anyone know what I could be doing wrong?
Text Font Design Diagram Paper
does not say.. Took this off their site. Anyway to rewire it or did they send the wrong one?
AOBSW600 series Illumination
When switch is turned on the top light illuminates.
The bottom Etching (words) has an Independent wiring circuit to connect to your dash lights. You can connect it to the dash light circuit or leave off, your choice.
Do your leds lights that you are controlling with this switch function properly
I don't think you will be able to rewire to work as you want. I think they sent you the wrong switch there is a option for that switch to have a lower dependent and upper independent led.
Look here and you can see all the different options for how the led's light up on these switches
OTRATTW
1 - 7 of 7 Posts
