There are 2 different rock sliders for sale. sport and just rock slider what one have you bought?
This helps! I guess I will put mine on. Thanks MaxView attachment 2793 No, the hole is there. You can see it from underneath. they are like 19" apart. Drill a small hole back through toward the outside, use a flashlight to see how centered you are and waller it with a die grinder to achieve center. Then you can use the hole saw to plunge into the plastic. I didn't do that. I found center and offered up the bar for fittment, tightened, used a scribe to lightly mark the outer hole, removed and used my die grinder with a blunt carbide burr to create the hole. Now when I offer up the bars, they will hang there with no bolts because the tolerance is super tight, then install bolts with blue loctite and finalize, like I said "challenging" to do it right otherwise the hole will be a wee bit big and mud will hang around the bar hole, hope this helps
