1 - 20 of 61 Posts
Official Site Vendor
(Free Shipping in the Lower 48 States)
Heavy Duty Rhino Axles For CanAm X3
PM for pricing.
https://www.proutvparts.com/collections/drive-train/products/rhino-2-0-utv-axles-canam-x3-by-super-atv
DETAILS
Why Rhino 2.0
SuperATV's Rhino 2.0 axles will change the way you ride. If you’re rolling in a Can-Am Maverick X3 you know you’re going to push your machine to the limits–huge dunes, extreme hills, and whole lotta speed. If you don’t have a high standard for axles, you’ll spend more time crawling with a busted CV than with your foot to the floor. That’s why you need SuperATV’s Rhino 2.0 axles. Built with over 10 years of axle and suspension experience, these axles are the toughest we've ever made, meaning you can push your X3 even harder. And they won’t drain your wallet either.
Rhino 2.0: Factory Engineered and Tested
We here at SuperATV designed, tested, engineered, and manufactured the Rhino 2.0 from the ground up. When it comes to your X3, you don’t cut corners, and neither do we. Your dealing directly with the experts and riders who brought this axle to life. We have millions invested in state-of-the-art testing equipment to help us create a superior axle with no break in periods and no risk of overheating due to metallurgical failures.
The Rhino 2.0 Formula
The Rhino 2.0 was really a passion project. We spent many late nights in our R&D lab and hundreds of hours on the trail to perfect the Rhino 2.0 formula. For Rhino 2.0 we focused on 2 things: strength, and longevity. We used 4340 chromoly steel with a proprietary heat treatment to achieved this. The result is an axle that can handle the insane power output of the Maverick X3, and whatever other shock you throw at it, without breaking. Another advantage of our proprietary heat treatment and material is the high twist yield–the Rhino 2.0 will flex A LOT before it will break, meaning that even under crazy strain, this axle will pull through.
The Rhino 2.0 Difference and 18 month warranty Every test we do, whether it’s yield strength, longevity, or heat buildup, shows that Rhino 2.0 is the strongest axle you can get for your Can-Am X3. Rhino 2.0 delivers strength as good or better than other super-duty axles that cost $550-$900 but at a fraction of the price. SuperATV is so confident in the performance of Rhino 2.0 that we’re breaking all the rules by offering this axle with an 18-month warranty! And as always, each axle ships free of charge.
FITMENT
  • Can-Am Maverick X3 XDS : 2017+
  • Can-Am Maverick X3 XRS : 2017+
FEATURES
  • Utilizes the Rhino 2.0 Formula
    • Size: Massive 4mm increase in size!
    • Materials
    • Heat Treatment
  • Constructed of 4340 chromoly steel and finished with a proprietary heat treatment
  • Industry leading 18 month warranty
  • Field and lab tested for extreme strength and endurance
  • CAD drawn for expert precision
TERMS OF WARRANTY
SuperATV Rhino 2.0 Axles (excluding boots) are warrantied to the original purchaser for a period of 18 months from the date of purchase. If the axle fails for any reason within 60 days from the date of purchase, SuperATV will ship a replacement axle free of charge. If the axle fails after 60 days, but within the first 18 months of the date of purchase, the purchaser must pay a flat $50.00 replacement fee. In all warranty cases, the purchaser must provide SuperATV with proof of purchase and proof of breakage.
rhino-2-test-comparison-chart_1_3.jpg polaris-rhino-2-axle-axp-7_17.jpg polaris-rhino-2-axle-axp-6_19.jpg polaris-rhino-2-axle-axp-4_19.jpg polaris-rhino-2-axle-axp-3_6.jpg polaris-rhino-2-axle-axp-1_6.jpg
I am the one that called you on the rhino 2.0 axle that I was installing on my rs X3 with a Halo. Just want to say thank you for your time talking to me on phone, once we cleaned the silicone off the actuator their is just enough room between it and boot band that it should not be a problem. Again big thank you.
Discussion Starter #8
Thanks for the call. I agree the clearance is tight, but workable. I think the RCV axles are as tight or tighter.
Discussion Starter #19
What’s the warranty process and exclusions?
TERMS OF WARRANTY
There is a form to fill out and send in.
TERMS OF WARRANTY
Good stuff. I’ll be contacting you for a set of fronts and rears very soon. I have 2600 miles on my Oem with no issues but want to replace for peace of mind.
1 - 20 of 61 Posts
