1 - 20 of 31 Posts
Ok so I've got my S3 cage on order and sold my audioformz roof and I'm prepping for the new system. Plan on 4 tower speakers Bluetooth module, amp for speakers and amp for sub.. This is where I'm stuck, not on brand of sub, but box for sub. Anyone have custom sub boxes? Looking for ideas
ssv works has a sub box go to ssvworks.com
Hey Brandon its Jacob the guy that bought your audiofroms top, all terrain audio makes a box for two subs that goes in the bed and still has room for a small cooler. I saw the pics on there facebook earlier today.
Not really any pics of mine, but here's how it goes: All Wet Sounds; WS-420, SD6 tucked in behind the dash bezel, SW-650's in kicks, SS10 in sub box under glovebox, black Rev8's. For the WS-420, I used one of the UTV, Inc flat metal dash plates and cut out for the 420 to mount. Also used a PAC-Audio ipod/charging cable to the main input of the 420.
Do the kicker systems have enough juice to drive 2 6.5s ? It says 25 watts per channel. Seems kind of weak but I like the clean install.
Sent from my SCH-I605 using Tapatalk 4
The kicker system is 25watts RMS not peak watts like some advertise but they do have a marine amp you can add if you want more power. I was going to get the Bluetooth version and if the sound was not loud enough then add an amp.
There is a thread on this forum that's shows the Kicker PXI50.2 installed in the center console area where most riders are installing gauges. You could probably still install 2 gauges with this stereo mod.
Take a look at this. 4 rockford 8's and the rockford 600 watt amp. This thing pounds. No need for subs. it sounds like it has them already. Plenty of bass. Technology Electronic instrument Vehicle Electronics Auto part
These are custom made. I did make the molds so I can reproduce them. Can make them to fit any size speaker. PM me you info if interested
Do you have a link to buy this?
Sent from my SCH-I535 using Tapatalk 2
You can buy the non-Bluetooth version from many online sources including ebay. I provided links to Crutchfield. They are not always the cheapest but very good customer service.
Bluetooth version
Kicker 40PXIBT50.2 2-channel amplifier with Bluetooth® and controller for iPod® or iPhone® ? 25 watts RMS x 2 at 2 ohms at Crutchfield.com
Non-Bluetooth version
Kicker 11PXI50.2 2-channel amplifier and controller for iPod® or iPhone® — 25 watts RMS x 2 at 2 ohms at Crutchfield.com
1 - 20 of 31 Posts
