The clutch kit will physically fit on the MAX, I think what he meant was the kit wasn't tuned for the MAX so it will not give you the performance you are seeking.I talked to Todd this morning...he didn't think it would work on the Max. I checked all the part numbers today and they are the same on the max and the 2 seater so I think it will work. But I saw someone mentioned that 30s will rub in the back in certain conditions....maybe I should go with 28s.
I guess in theory you are correct but that is assuming that the stock clutching is correct to start with which we know it is not. I would contact Dalton directly and speak to them and see what they have to say.....I would hate to drop the $300 or so and find out it is not correct.Correct....but they factory springs and weights are all the same, so they kit should do the same to a max as it does to a 2 seater.
I agree...that is why I have decided to go with 28 inch bajacross. And see how they do and adjust the clutching from there.I guess in theory you are correct but that is assuming that the stock clutching is correct to start with which we know it is not. I would contact Dalton directly and speak to them and see what they have to say.....I would hate to drop the $300 or so and find out it is not correct.
good call....get the tires you want first and then dial it in....I agree...that is why I have decided to go with 28 inch bajacross. And see how they do and adjust the clutching from there.
The model year 13 weights are commander style weights. What they found is due to the changes in the maverick primary vs commander in some elevations/conditions the weights just weren't ideal.So they kept the PN the same but changed the actual part......Sneaky!
Have you tried swapping every other weight with the low altitude weights (original) and see if you get a good compromise that works better all around?I ordered new weights today...the sea level weights are $132.00 for a set of six. The 4000 feet and 8000 feet are 40 bucks a piece. I swapped them when purchased it because I thought it would run a lot better at altitude....it does but the gain was. Ot as much as the trade off for over reving at 4000 feet.
I hope I get the "new style" ???
