1 - 7 of 7 Posts
Do they make a rear window for the xmr? All the places say they don't fit the xmr. Looking for a solid window and not a screen but not having any luck.
I put spike rear on mine . They said it wouldn’t work but it does . No modifications and even has sliding vent .
Discussion Starter #3
Looks like it curves in at the top and might not work with the sound bar unfortunately.
Discussion Starter #5
Mounted on the top bar with the L shaped mounts on the sound bar on the ends? Not the best picture but you get the idea how it’s mounted.
I used the sliding bolt mount that can be slid in run the sides. There’s 2 bolt holes on the cage to mount to. It does angle the bar up a little bit doesn’t effect the sound . I’ll take a pic when I get home here in a few and show you.
Here you go. Pic is not the best but I think you will get the idea.
1 - 7 of 7 Posts
