Whats it take to change them out for someone who sucks at fixing things?
I actually just did mine yesterday with the upgraded O-rings from heavysledz...
It Isn't too bad. 17mm Socket and an 8mm Allen?
Jack up the Bike so tires are in the Air, remove one Shock...
The Bushings or Metal Collars on mine were a bit of a PITA to remove after 60+ hours.. Took some prying and hammering with a Flat Screw Driver to get them out. Also Some penetratiing oil maybe necessary. (PB Blaster). Once you get those Busing or collars out, Remove the factory Seals. Clean up any dirt or Crap in there, Clean with Brake Clean and Blow out any excess and let dry. Apply some Grease to the metal busing / ball (I used High temp Wheel Bearing) re-assemble with New Seals.
On those Metal collars / busings. Also Clean those up real well with a Brush and Brake Clean. I applied some anti-seize before putting them back in to make sure next removal will be easier. Also Applied some anti-seize to the Shock Bolt too.
re-install...
Took me about 30-45min a corner. Most of the time was spent trying to remove those Stuck Bushings / Collars / Sleeves.... What ever you want to call'em
