It's a known thing that the rear shock tune on the XRS Maverick is less than desirable. We've gone through numerous tunes leading up to our dual rate setup to maximize the factory springs and setup as much as possible at a very affordable price.
We modify the compression side and completely change to rebound side to fix some common complaints. We also add oil and up the nitrogen pressure.
This will result in a softer rear suspension along with a more controllable rear rebound that eliminates rear bucking and stays planted in the whoops.
$200 - please have your shocks clean with the springs removed. Turn around is generally one day and we can do same day tunes if needed.
