1 - 20 of 63 Posts
Discussion Starter #10
Why is everyone bending their radius rods? To justify cooler looking ones to their wifes??
Must be the pretty looking thing, I have 3100 hard miles on mine and have not bent one. Just figured I would cut and sleeve mine because I can and I'm too cheap to spend $700 on links. $64 in material and some welding time is all it took.
Driving like a little lady in her way to Church is NOT hard miles! Lol.
You know that is all in the way you hit somethings. A lateral load and that center fuse does its job.
I did do after market, but there is something to be said for the stock theory of having a place to absorb the blow and leave a relatively inexpensive item damaged.
Discussion Starter #13
Mega, have you grabbed a rear wheel at 3 and 9 o'clock and tried wiggling yet?
No, I have my links off right now sleeving them. I did check the middle holes in the rear up rights and they are not wallowed out at all. Ill check this weekend when I fix the broken area.
Are you planning or do you see a big need to make the uprights double shear? Tim
Discussion Starter #15
the upper and lower are double are double shear. Its that damn middle one that needs some love. Its difficult to support because it moves with wheel travel. I think ZRP has the only real fix with the new upright and integrated second tab. The Assault and Lsr bolt on supports don't add much in my opinion.
But before I tackle welding to the rear uprights I have an exciting to me product to develop and test.
I got all my bolts tight, added a rear plate that tied into the cage and therefor the frame, and did all I could but I could not get rid of the wiggle at the wheel. Finally located it to the radius rod ends. That wiggle was driving me crazy, call me ocd, but every time I would hit the gas I would think about that side to side play and I hated it. So that is what really made me want to spend the money. Plus I tried a cheaper aluminum radius rod set and no change, so those went on the scrap pile for me to practice my AL welds.
As soon as I went to the ZRP rods the 9 to 3 wheel wiggle went away.
The stock BRP bushings are crap!
Reactions: The Dude!
1 - 20 of 63 Posts
