You owe me.......LOLYou owners manual tells you the correct fluids. Yes the drain plug is a mother effer use a 5mm Allen with caution. I am searching out a replacement plug Friday. I will sell the info after I find out what it is. Haha
you poor SOB i thought of you when i pulled out the diff and removed the crappy drain plug. I got you covered Andy.You owe me.......LOL
Yes it is. Just did mine last weekend and had to reach around from the front with the wrench to get the drain out. All while sitting behind the machine. Then as usual oil starts out going right through the hole into the bucket but when the level drops it begins to puke all over that non removable mini skid plate. Makes a nice mess. As I remember 75/140 was for the gear case only and front and rear diffs use 75/90. All synthetic.Is the rear diff a bit if a bugger to change the oil on? Pictures? And is a synthetic 75/140 good enough?
nope, great idea. works great for me.i am thinking about cutting a bigger hole in the skid plate. bad idea?
stripped my nut, now what? Just leave it in and suck it out?nope, great idea. works great for me.
