1 - 8 of 8 Posts
2013 Maverick 1000R...
rear diff pinion seal and bearing is worn. i want to replace all the bearings/seals in the rear diff while i have it out. I've searched high and low and can only find bearings and seals for the Front, but i need them for the rear.
does anyone on here know the part #'s for the rear bearings and seals?
any help at all is appreciated. TIA
Discussion Starter #3
yea I had seen those parts lists already, but there weren't any part #s for the bearings I needed. my local napa had them in stock. I replaced all of the bearings and seals and shims. and yet again the pinion seal is leaking. It was installed correctly and not damaged at all on installation.
There is a wear ring on the front driveshaft that goes into the diff seal just replaced mine.I don't know if the rear has one or not,If it has a groove wore in it replace it.
can you share the bearing numbers? thanks
what was the trick to put the new one on?
Exactly what I want to know ? How do you seat the wear ring on the end of the yoke/prop shaft
1 - 8 of 8 Posts
