1 - 2 of 2 Posts
Our heavy duty chassis braces will increase the strength and rigidity of the radius rod mounting point. They also feature a tow hitch receiver or hook to bail you out when you're stuck! Both made in America and compatible with all Canam Maverick X3's.
Rear Chassis Brace With Tow Hitch:
  • Integrated tow hitch receiver (2in)
  • Reverse inset receiver for a clean, low profile look
  • Improved rigidity
  • Hitch points built-in (For securing to trailer)
  • Made from 1018 heavy duty steel
  • Double Shear
  • Compatible with OEM and aftermarket radius rods
Billet Rear Chassis Brace With Tow Hook:
  • Improved rigidity
  • Billet black anodized tow hook
  • Tow hook doubles as hitch/tie down point
  • Made from 6061-T6 aluminum
  • Raw aluminum finish
Check out the tow hitch brace HERE and the billet brace with the tow hook HERE. Use discount code MAVF2020 at checkout!
266739
266740
1 - 2 of 2 Posts
