1 - 3 of 3 Posts
Hello everyone I ripped the rear boot on my can am x3 and I'm trying g to take the axle out and it is not coming out I did the normal push and pull and nothing
you have to pull straight out, no angle at all. If you need a little help you can put light pressure between cv and rear diff. Becareful not to crack diff. Make sure to use plenty of neverseize when re-installing.
Official Site Vendor
What mega said. I use the axle like a slide hammer and get someone to pry between the axle and the case. Should pop out on the first or second pull. Spray some penetrating oil on the shaft where it goes in the diff may help.
1 - 3 of 3 Posts
