correct but i have two mavericks with a qsc on both. everything is X2
Correct but i have two mavericks both with a qsc primary so everything is X2The QSC only has three weights.
Ya they have a fiber material in them. How old are your clutches? That's discouraging.[/QUOTE
one has only 176 miles on it. other maybe 900
Yea, it turns fine. not like a ball bearing but it spins easilyDid you try and turn the bearing on the primary? Feel ok?
Nathan - mine isn't seized but something sure isn't right. According to STM, you should have it as tight as possible without squealing or creeping…. take a look at the video and let me know if this looks right or not? BTW I only have 2 fiber washers in it….Dude that is exactly what mine did when the one way seized up. I may be wrong but I'd say add at least one shim if not two. That's just my opinion tho. I've got two more shims in mine than what I had with the original belt and it seems good to me, I'll know tomorrow when I can take it for a spin.
I measured them at the very top (widest part of the belt). What is the proper way to measure them?Are your belt width measurements taken at the cord layer or level?
