.. X2go with the superatv set up. Great product and easy install.
Sent from my iphone using tapatalk
What was the cause? Bend a tie rod? low air in 1 of the tires? Hope you find out.Today I had a problem with my super atv ps.... I was driving and suddenly the ps start to turn to the rigth side with no reason.. I almost crash ... What is the problem...?
kind of impossible to diagnose with so little details. Did you check to see if you had a flat or bent/broken tie rod or radius rod.......did it do it once and then go away or does it do it continuously? Can you force the steering back or does it fight the wheel????Today I had a problem with my super atv ps.... I was driving and suddenly the ps start to turn to the rigth side with no reason.. I almost crash ... What is the problem...?
X 2Call Super Atv immediately!!!
Devious PowerSports ,Tyler
I am sitting here thinking how a power steering unit could make it turn. It assists in turning not makes it turn.
