1 - 11 of 11 Posts
I have a 2014 Maverick DPS 1000r, the steering recently started momentarily locking up when first starting to straighten up out of a hard right turn, usually when making a right after stopping at a stop sign and accelerating, it’s an intermittent problem, I’ve tried switching between the min/med/max DPS modes and it doesn’t seems to make any difference, Shop mechanic drove it and it didn’t do it for him, any ideas on what could be wrong?
Our completely stock 2017 XRS max 1000R is acting similar. Feels like the rack binds up periodically then works fine for a bit its very intermittent and I never know what to expect coming into a turn. Some models had a rack recall!
How many accessories are you running when it happens? Light bars, stereos?
Stereo usually on but no light bars in daytime. Weak battery was my first thought but voltage is 12.6 when off and 14.4 when running. Might put a new battery in and add the original one for accessories just to rule it out.
Well I am running two batteries and ever since I added the particle separator and swapped to the ST race rack, I am experiencing the same things you are. But I’m running a 8 speaker stereo system and have light bars, chase lights, Navi, etc. it all works fine until those lights are flipped on then the lower draw overwhelms the stator.
The fix was the ZRP alternator. Pricey but u may look into it
Discussion Starter #6
My issue is when you start coming out of the turn, it just hangs up for a second then it’s back to normal, l haven’t been able to find any recalls for my model.
Discussion Starter #7
All l have is the stereo and the street legal kit, l made it a point to not use the turn signal and that didn’t help but haven’t tried turning off the radio.
Yeah mine progressively gets harder to turn going into or coming out of a turn. I’m still thinking it’s a voltage issue
Discussion Starter #9
It only happens for a split second but l live in south central Utah (home of the Rocky Mountain Jamboree) and there are a lot of windy cliffy roads, l think my next step will be taking all my electrical connections apart and cleaning them.
There’s also the E steering systems u may look into but there will be a voltage concern as well. I don’t have the E steer but I hear it’s the shit
Discussion Starter #11
Thanks for the info, l will look into that if l can’t figure out the problem.
1 - 11 of 11 Posts
