Are you in limp mode? Does your gauge say that?
Has it been sitting a long time?Here is the story ,I started my Can Am and drove approx 1/4 mile shut it off then 15 minutes later started it and drove real slow about 800 ft stopped then shut it off and about 1
Minute later started it snd it sounded different drove it and it feels like it dropped 1 cylinder. Next day I started it and same thin no power.
No gauge says nothingAre you in limp mode? Does your gauge say that?
maybe a week of sittingHas it been sitting a long time?
Ok that at least should rule out bad fuel. Have you looked at your air cleaner to see if you have a guest living in the air box?No gauge says nothing
Checked with heat gun only hitting on one cylinderOk that at least should rule out bad fuel. Have you looked at your air cleaner to see if you have a guest living in the air box?
it’s a 2015 I’ve pulled the plug , it gets spark and slightly wet.What year?
you nailed it,I replaced the plugs and it fixed it.Short run times tend to foul the plugs, when's the last time you swapped in a new set?
