We will be releasing our 30x10R15 Growler XOR DOT tire in February.
Also available late January we will be introducing our Growler BG2.5 Radials in the following sizes and corresponding MAP prices.
26x9R12 - $118.99 - approx 29 lbs
26x11R12 - $133.35 - approx 36 lbs
26x9R14 - $122.06 - approx 28 lbs
26x11R14 - $139.50 - approx 36 lbs
They are about $200 cheaper per set than the Growler Uber XORs.
Notice that they are normal sizing instead of 1/2 sizing. 6ply-rated radials with the extra deep rim guards. I will tell you that we've tested these things extensively on many extreme machines and in many terrains. Just like all Pit Bull ATV tires...these are larger OD than stamped and are heavy duty construction. I am impressed and I think you will be too.
1" Fronts Tread Depth
1 1/8" Rears Tread Depth
The major differences are the price and OD. Factory has the OD at 26.77". OD is subjective and determined by measuring rim, psi...etc. This is an approximate number, but you get the idea.
Most of our dealers have pre-ordered...and they are in transit with ETA January 18.
Results are showing that they wear incredibly well...2Xs better than a top brand I won't name. Also...they have the same incredible traction of our Growler Uber XOR. These are seriously well-constructed tires.
25x8R12 and 25x10R12 will be available in March. 27" available in July.
Let me know what you think.
