1 - 1 of 1 Posts
Supporting Vendor
Make your capable machine even more useful during the snow season by equipping it with a snow plow system. Whether you need to clear your snow-clogged driveway, yard, or street, snow plow systems offered at POWERSPORTSiD.com will surely help you get the job done. You can use some of the models in summer too for moving piles of sand or gravel. We offer a wide variety of blade types and mounting systems. You can choose a suitable size depending on your machine’s engine displacement.
Front-mounted plows are quick and easy to install. They have higher blade lifting capabilities. Center-mounted systems offer greater rigidity to the vehicle’s frame during plowing activities. Note that the center-mounted system reduces the ground clearance, which means you may want to take the plow mounts completely for the summer. To increase traction in extreme winter conditions, try using a set of tire chains that bite into the icy road surface or hard-packed snow.
Standard Series Straight Snow Plow Blade by Denali Plows® at POWERSPORTSiD.com
Auto-Lock T-Frame Extendable Articulating Push Tubes by Quadrax Utility® at POWERSPORTSiD.com
Check out all Snow Plow Blades, Push Tubes, Hydraulic Systems, and Plow Mounts and Hardware at POWERSPORTSiD.com
Talon Tire Chains by Eagle Plow® at POWERSPORTSiD.com
Helene Series Premium Studded ATV Chains by Trygg® at POWERSPORTSiD.com
Browse the full catalog of ATV&UTV Tire Chains at POWERSPORTSiD.com
Click on the image to enter the product page and check fitment.
If you have any questions about these products, their features, how to use or mount them on your Can-am Maverick, feel free to contact me here or call our tech specialists at 888.903.4348​
1 - 1 of 1 Posts
