21 - 40 of 1647 Posts
For glamis i love my 30 inch 8 paddles xtremes on cms. Did i notice much of a difference duning compared to my doonz paddles no, but drag racing. Whenever i drag race first thing i do is look at their paddles. If they arent skats good chance ill win with only 110hp. I pulled up to a few turbo yxzs they looked at me funny. They said go. One jumped out on me i ran him down another never caught me in my short bus
What was your wheel speed and rpm at the top of choke?
I know, here we go again!!!
Matt
Discussion Starter #23
rpms in 4wd were lower then I want, around 7200 in 4wd, 7650 in 2wd, was at about 44mph topping the hill.
3 weeks before when it was wetter and more compacted, 55mph at top around same rpm
We had similar rpm results during our trip on drier sand. They definitely need some tuning help to get the rpms up to 8100.
Narrow wheels work great so if if you have a 6" wheel then run it. Even the Guys over at UTV Inc like the narrow 7" wheels.
If you feel like your gonna need more paddle for your riding area for sure paddle up. You have countless ways to build the Skats where as with a Molded tire you only have about 5 ways to mod them.
Warlock what makes a narrow wheel good to run? Seems so counter intuitive - makes the contact patch narrower, takes away flotation...
Preference for me to keep the car narrow, that's why I run a 12pdl staggered's to compensate for off the line acceleration. The added sidewall makes for a smoother ride too.
Hi Guys.. i am on a budget.. about 1200 max to spend on paddles and wheels. would like some opinions. i have a pwrtune stage 1 tune. i am looking at a package of CST sandblast 30x12x14 rear, 30x10x14 front. Mounted on STI HD5 machine beadlock 14x9 rear, 14x7 front. Also, not sure what offset to run, if any. Any comments appreciated. Thanks!
14x14 Skats Extreme on a 10 inch Douglas Ultimate, no bead lock, just a bit over 30 tall with 12 paddles.
Very good out of the hole, felt really good at low and high speeds, weighs in at just over 30 pounds which is the same weight as the stock tire before you add a rim.
Started at ten pounds, ended up at 9 for the rest of the weekend.
The offset put me at 79 wide.
Imagine the floatation of say a beach ball as it is rounded like what a narrow rim will cause so the tire can flex and bulge instead of stretched out on a wide wheel.
How do you think those low riders ride with them stupid wide rims with the Bead stretched out and stiff as hell.
Reactions: oneshotkyle
I like mine, they have a nice drifting ability. I run 5+5 rear wheels and 5+4 front wheels IMG_0359.JPG
It's a good set up. My buddy runs them on his YXZ.
Reactions: Dunerxds
I know this isn't the classifieds, but I may be selling my 30x13x14 Warlock tires 12pdl stag extremes on cms wheels. Just a thinking out loud.
Are there any dunes in Canada? Or do you ride at St. Anthonys?
There are the Brule Dunes on the Athebasca River in Western Alberta, about 6 hours away from me.
you can Youtube to see what they are all about.
St Anthony is 11 hours door step to door step.
I met a guy from 23 hours away so I consider myself fortunate.
Plus I like how nice everyone I've met at St Anthony.
My new turbo will be replaced on Tuesday and then its 59 more days till we get back there.
23 hours is nothing, LOL. So far in Glamis, I've met people from England, Germany, Italy, and wait for it...... Australia! And it was a group of about 10 - 15 of them. Met them at Olds.
Reactions: maxdun
