Paddle comparisons for X3
465K views 1.7K replies 146 participants last post by  Speed Buggy
I know, here we go again!!!
Matt
#1,078 ·
Also can allow the car to slide the ass end easier depending on how flat you make the tire profile with the wider wheel. Think of the Funco cars with the wide flat profile rear tires (some of the best handling cars in the dunes).
#1,080 ·
Since the aftermarket hasn't caught up with the times yet I guess I am stuck running a 14" for stock offset. That said, my option is either a 7 or 8 wide wheel but when talking with Tim at Xtreme he said he doubted I could see or feel a difference in one inch. Wouldn't mind a littleflatter profile.
#1,108 ·
I usually run on a 10” wide rim, with the exception of the CMS setups I’ve ran in the past. I’m inquiring into the personal found differences in duning the 10” wide rims staggered extremes vs the 8” wide rims. What’re the pros and cons....
#1,109 ·
I'm not sure to the 10" comparison as I've never ran any wider than an 8" with skats. Seems some guys like to slide and drift through terrain. I really like the feel of a car that bites and stays planted. This time around my wheels are only 6" wide, because if aftermark offsets I decided to give it a try. May not be the holy grail. Time will tell
#1,110 ·
Wider rim will float, skinnier will dig. Wider rims will make tires shorter, skinny make tires taller. Wide rims will have a flatter paddle blade, skinny will be a curved blade. Mine and kyles paddles wrap the sidewall as we are running staggers on skinny rims, his are extreme skinny and prob pretty light as well. On skinny rims w/staggers we basically create a side grip or side bite out of our paddles. Don't know if its better or worse, but I know you don't want to ride behind me.
#1,129 ·
why doesn't extreme offer a turning tire to go with their big tires as part of the match sets? This isnt about whats faster and we know the shaved tire does help in 4wd, but why not a ribbed or grooved tire for those that want a little more control / predictability when changing direction? Not talking about the tribute mini paddle, just a rib like all the sand rails run?
warlock, why doesn't the other Tim make those as an option? I would think there is a demand for them as some will sacrifice the drag it creates for drivability depending on driver style sand dune location
#1,132 ·
Tim doesn't like the idea of the front tire rib making a disturbance in the sand that the rear tires have to fight. The smooth tire packs the sand for the rear to have a good surface for traction. Rib tires really don't offer a bunch of input on steering but the sure help fling more sand in the air. We drive our car a little different I guess also as I tap the brakes before the turn set the car and go into the turn.
Reactions: oneshotkyle
#1,143 ·
30" CST Sandblast mounted on 14x8 STI HD9 wheels weigh 43.2 lbs.
Big Horns on stock wheels: 45.6 lbs
I decided to remove the nubs on Sandblast and that took the weight down to 41.7 lbs
Reactions: DustinzXRS
#1,146 ·
We ride at Little Sahara in Oklahoma. The dunes are small compared to out west, and there isn’t a ton of room to open the machines up like most people have. We rarely get up past 60-65 mph before I shut it down. Armed with this knowledge, and the fact that I’m set on getting tall skats, would the 12 paddle staggered rippers make a good choice? I’ve got stage 3 evo tuning, full hmf exhaust, evo intake, evo clutching. It’s a 2017 Max. I’m calling Tim today at Xtreme, just wanted to shoot for a few last minute opinions. I’m open ears, I just don’t want to be under paddled. Not concerned about how fast I can run up a huge dune, because those don’t exist for us. Thanks guys
