How long was it at that temperature?Hopefully the 236 doesn’t damage the engine. I’m not sure.
probably would be hard to tell running in that much snow as snow alone will feel different than on dry dirt roads.I bet it it handles awkward with all that extra weight.
Yes snow on the radiator will bring those temps right down. I use to run my diesel truck in the deep snow and it ran so cold the heater would only blow ice cold air.I would have been throwing some loose snow on the radiator to help cool it down...lol. I've clogged the radiator with mud before but never snow and ice...lol
I suspect the thermostat was stuck open. The t stat is designed to allow the engine to heat up to temperature regardless of the outside temp.Yes snow on the radiator will bring those temps right down. I use to run my diesel truck in the deep snow and it ran so cold the heater would only blow ice cold air.
It was on my 2000 Powerstroke. We were running in 3-4ft of powder with the snow plowing over the hood. Everything had snow on it including the engine thats why the heater would only blow cold air. Having a 6 speed manual transmission tends to keep everything cooler under the truck. Auto would probably help warm things up some.I suspect the thermostat was stuck open. The t stat is designed to allow the engine to heat up to temperature regardless of the outside temp.
Another thing is if the defroster is on the AC compressor cycles on and off.
I'm doing a ride this weekend where we will likley see snow. I'm looking forward to the rode but but not the snow!
Keith you're a pretty mechanical guy, that's clear from your build and I've seen it first hand on the trail, but that explanation doesn't make sense mechanically speaking.It was on my 2000 Powerstroke. We were running in 3-4ft of powder with the snow plowing over the hood. Everything had snow on it including the engine thats why the heater would only blow cold air. Having a 6 speed manual transmission tends to keep everything cooler under the truck. Auto would probably help warm things up some.
that's because they don't like cold weather/air.. they run WAY better when it's warm outsideI know nothing about diesels (never owned one), but I do know that during cold weather I see plenty of them running down the highway with a cover over the front grille in an effort to keep the engine temps warm.
