I'm affaid I won't be very much help since I did this over a year ago, but here's a pic of my center console. I installed a center console for a radio/gps unit & intalled the gauges were the GPS would mount. Mr RPM has a spin on oil filter adapter that has a extra port you can install the oil temp sender. I went a different route w/my oil temp sender, it is actually in the oil port in the block between the two cylinders. Good luck trying to find a sender that fits thou - It took me a few attempts a some light mod work to get it right. For the water temp there is a plug on each head you an use, there have been a few posts on this - I just use my stock water temp gauge.
