I installed some gauges (oil pressure, water temp, voltage, belt temp) and was wondering what others are getting for oil pressure. Here is what I am seeing:
- Cold engine at idle 50psi
- Hot engine at idle 25psi
- Cold engine off idle (4-7K rpm) 55-62psi
- Hot engine off idle (4-7K rpm) 43-55psi
Do these numbers look "normal"....especially the pressure at idle when the engine is hot. For what it is worth, I am running a mechanical pressure gauge and not an electronic unit.
