1 - 9 of 9 Posts
Thanks,, Yea I'm thinking if I went with 10s on the front that would bump me back out a little? wondering if anyone runs this set up or something close?
6+1 on a 10 wide tire should have you in the 64 area as a 5+2 setup will have at 65-66 with a 10 wide tire. We've done many of these setups. Mine with 5+2 methods and 9 wide Dirt Commanders front and rear is 64 wide.
5+2 will make you a inch wider in front. stock offset is 1.5 front and 2 in the back. you should be 63 in front and 62 in the rear. where did you find 6+1 offset for the maverick? nevermind see link now
Discussion Starter · #6 ·
Click the link in my first post STI makes the wheels. I'm sure one of the vendors like CT can hook you up? If not let me know...
1 - 9 of 9 Posts
