1 - 4 of 4 Posts
I own a 2018 XRS turbo R will this battery fit upright with stock hold down strap or do I need to modify in some way if so what mods will I need to make thank you for the help
It would be pretty easy to make your own strap.
The 925 doesn’t fit upright and the stock strap it too small. The above kit is sold with a left side positive post and the battery placed with it’s bottom facing aft. This lets you use the stock hold down attachment in the back of the battery box and puts the pos/neg posts nearest the factory wiring. The larger battery will cover the two bolts that secure the factory hold down.
I bought the above kit which made things simple.
1 - 4 of 4 Posts
