121 - 121 of 121 Posts
Discussion Starter #121 (Edited)
Thanks for the input, assembly was a bit of a pita so it would be easy to just leave the a arm bolts in but I'll take your advice and source some top grade bolts before I run it next. As a side note, I'm looking behind the firewall to see if I can anchor the lower aluminum plate to mitigate the risk of it pulling forward.
Sent from my HD1925 using Tapatalk
Now that I look at the pictures it would be easier to insert the bolts from bottom and slide the whole assembly into the OEM tabs. I also wonder if the added diameter of the aluminum bushings increase the shear of the bolts considering it is all clamped together. I'll still upgrade the bolts but I think the weak point now is the OEM tabs.
