Enclosures:
(For Can-Am Maverick X3 and X3 Max): SSV Works custom molded kick panels designed for 6.5" speakers and bolt into the upper foot well away from your feet. They are 100% fiberglass for the best sound quality and bass response. They are finished in a black texture coat to match textures and can be custom painted to match your color scheme. - Includes stainless mounting hardware and step-by-step installation instructions.
Speaker Options:
SSV Works Powersports speakers:Get louder, cleaner sound even in the dirt and mud. Engineered specifically for Powersports, the new WP-A6 WeatherProof speaker brings audiophile grade components to the outdoors. The 25mm Ti- tweeter creates crisp brilliant highs engineered to be heard outdoors, even in a helmet…over the motor…haulin’ down the trails. The grille mounted tweeter allows for peak cone travel creating maximum output while providing a low profile with optimal weatherproofing.
Marine speakers are great for boats; however boat speakers don’t get as wet, dirty or muddy as you do in a Side X Side. WP-A6 speakers feature an EPDM duo lock gasket surrounding the speaker to keep the water out and the sound pressure in. EPDM conforms to the surface and seals tight no matter where you ride, in direct UV, extreme heat, or in freezing temps. Reliability meets control with the Santoprene surround; a 30% lighter thermoplastic elastomer surrounding the polypropylene cone for exceptional volume and clarity in the harshest conditions.
The SSV Works WP-A6 speaker features a unique positive lock connector to prevent speaker wire detachment inside the enclosure. No matter how hard you drive, your speakers will keep on rockin’ with 4ohms and 60w RMS/120w peak power.
*Multiple Patents Pending*
Kicker KM Marine Speakers: Spectacular highs and midrange sound provide full-range audio specifically for a Powersports/marine environment - 6.5" 195 watt (65w RMS) 2-way coaxial speakers.
Without speakers: order em empty. Already have speakers? This is for you.
To order, please visit the following link.
SSV Works - Side by Side Vehicle Specialists
Speaker Options:
