61 - 66 of 66 Posts
Just got done riding my first ride with these handles installed my only complaint is it doesnt appear the spring keeps enough tension on the rod to keep the handles pulled forward when not being used. I have the shoulder bolts loose enough so its not binding up there but when i open the doors with the handles installed I have to manually push the handles forward for the latch to catch when then doors close. has anyone replaced the spring with a stiffer one to keep better tension on the handles?
Its not the spring. The metal shaft rubs against the plastic insert on the door keeping it from returning. I notched out the plastic cover with a dremel.
ill have to check this out there appeared to be plenty of space between the cover and rod but ill double check
Better put these on the list to get also. Didn't realize a ghetto strap was the means to open the door. What were they thinking??
61 - 66 of 66 Posts
