The Assault Industries communications roof mount was designed to help make space in the cabin. As dashes get more compact and dash mountable accessories become more plentiful, it will be important to have some place for communications hardware.
The roof mount was designed around Rugged radios but may work with other brands with threaded mount holes on the sides of the unit. Elevating the electronics in the vehicle also makes damage from water intrusion less likely. Mounting holes are also available for accessory plugs, switches and buttons. There are holes on both sides of the box near the back for routing electrical wiring.
A soft foam strip is sandwiched between the roof mount box and the vehicle room to minimize noise. The Communications roof mount is designed and manufactured in the USA and powder coated black.
[ NOTE: The roof mount box should be mounted to a flat roof. ]
NEW Assault Industries Communications Roof Mount (Universal)
