1 - 6 of 6 Posts
Hey guys, I have 19 x3 Max with only 18 hours on it, and just noticed the passenger rear has negative camber. Any tips on what it might be or what to check first? Thanks
254206
Contact Scott_F (forum member) by PM. He sells a kit to replace the crappy studs that fit sloppy into the frame where the radius rods mount. They are shouldered to fit perfectly into the frame. Then they bolt in with the correct hardware. That will fix the problem permanently, as long as you don’t bend something.
Basically, the studs have so much slop in the factory frame holes, your whole plate moved back there and allowed the radius rods to move right, creating your problem. You probably have some positive camber on the other side.
1 - 6 of 6 Posts
