1 - 14 of 14 Posts
So just recently bought a 2020 can am x3 xmr max turbo rr and everything was fine. Rode it for a couple hours. Next day I noticed that there’s like clicking sounds when I start driving, it’ll start almost bouncing back and forth, and the right tire will slightly spin while the left one just rolls fine. Could do this be a bad axle? Or any other ideas it could be ? Also noticed that it has a higher rpm before it’ll start to roll on its power and it’ll start rolling hard. Not smooth. I’m sure that that could just be a spring making it a higher clutch engagement or could it be something else?
Welcome from Tucson AZ. Clicking sometimes indicates the CV is on the way out. Did you buy it new? XMR is a mud machine, so you are in mud a lot? Could have gotten dirt / mud in there possibly.
I bought it used with about 50 hours. And I haven’t been in heavy mud. More light stuff. I figured it could be an axle wasn’t sure. It does sound a little bad.
Welcome from NW Oregon
Front or rear?
"the right tire will slightly spin while the left one just rolls fine" ....is this on a dry or slick surface?
What RPM is does it start to engage? Have you had a chance to stab the throttle at a roll to WOT up to 50mph and read the RPM?
Discussion Starter · #10 ·
Front or rear?
Rear right spins. And on either surface. Had the belt break today. Replaced it and it seems to not be doing it anymore
Discussion Starter · #11 ·
Front or rear?
It engages at about 2500 rpm. I’m not so sure about about the WOT rpm
1 - 14 of 14 Posts
