1 - 2 of 2 Posts
Well I was doing the 10 hour service. I cleaned the VSS and when I reinstalled the 4wd accuator it makes a loud squeaking noise when i try to put in 4wd and it will not go into 4wd. I put in 4wd before removing. Can anyone help me?? Is the pin suppose to go in the middle of the accuator forks?
thanks!!!
Same thing happened to me. It can be tricky to line everything up the first time, but that pin must go in the middle. You'll have to manipulate the 2 pieces by hand and eyeball things good to make sure it all lines up correctly before seating the VSS sensor back into the case. Took me 2 or 3 attempts, but got it done.
1 - 2 of 2 Posts
