Hello,
I spend today 6 hrs. trying to get my clutch setup correctly.
I think I'm on the right track but still some finetuning needed.
I pull my hat to all clutch tuners.....once you pulled the flyweights a few times, it's getting old :crazy:
May this thread will help one or another down the road.
Here is what I have.
Maverick 1000, stock tires, stock motor (besides clutches :smile
I ride at 6000 feet elevation.
Primary has the gold spring, secondary has the pink spring and a 42 degree hélix.
Here is the progression throughout the day.
Starting point: this run was done in ECO mode, so it's no real comparison.
Tungsten at the heel, 2 Washers center, 4 washers at the tip.
Tungsten at the heel, 2 Washers at the center, 2 Washers at the tip.
Tungsten at the heel, 1 Washer at the center, 1 Washer at the tip.
Tungsten at the heel, 0 Washer at the center, 0 Washer at the tip. I hit the rev limiter at higher speeds.
4 Washers at the heel, 0 Washers at the center, 1 Washer at the tip. I hit the rev limiter first time at 65KM/H, kept hitting it.
