I installed the Muzzy's full system and the digitune a couple days ago. Only problem I had was getting eveything away from the frame. On my first test drive as soon as I got over 1/2 throttle it let out a horrible tinny crappy sound. Turns out one of the pipes had settled down onto the frame and was causing a high freq. vibration. I fixed that and removed the quiet cores and all is well. Sounds beastly!
There is a definite power increase for sure. The Mav squats a TON more than it did with the stock exhaust on it! I still have some tuning to do with the digitune because it's running a bit lean 13.6-13.9 according to the latest run I did.
Im hoping it will now beat my Wildcat X in a race. 28" tires and all the weight on it is slowing it down. After the QSC/STM is installed im told the Mav will kill the Cat by a good margin. Can't let the wifes kitty beat me now can I........
Edit: Noise problem not solved
Sent from my SCH-I605 using Tapatalk 2
