1 - 11 of 11 Posts
Today was the first opportunity I got to start the install. I don't want to turn anyone off from doing this but it is not fun. Takes a while to get the stock system off.
I am sure it will not get finished today, hopefully Monday or Tuesday most likely Tuesday it will be installed.
Just hard to do it and run this place at same time.
I sure hope it adds some HP for the effort required.
Todd
pics or write up or any install tips, hunterworks style ,
I agree. I actually had to cut my front header pipe just in front of the bolt-on flange below the drivers seat. Simply could not get an allen wrench on 1 of those hex head bolts to turn it. However, the good news is, the Muzzy goes on WAY easier and I believe you wont be putting the stocker back on after your dyno test. JMO.
I had no trouble with what you said. I have a wobble socket though
Really? I had no issues what so ever taking both header pipes off when I heat wrapped them. Did you drop the skid plate and access the front cylinder header from underneath? I did and it was a piece of cake....
Wait, I read this again, you had issues with disconnecting the header from the flange near the back? I just used an allen head socket with an extension and the air ratchet with no clearance issues....did you try to remove it with the CVT cover on by chance? Taking it off gives you tons of access.
bet it will be worthwhile and sound great
I had plenty of access but the short end of my regular allen would not fit because the pipe has a slight bend right at the flange. SoI ent and bought a socket and then could not get it on either. So I got pissed and broke out the sawsall. Problem solved. Skid plate was removed and had plenty room ot owrk around the CVT cover.
wow…I will consider myself lucky then……I sweat more wrapping the exhaust then I did taking it off.
I had a hard time with that one too but after removing the clutch cover there was plenty of room.
1 - 11 of 11 Posts
